Need Help 9N
Richard44
New User
Hi, at my wits end with this tractor. A bit of history. Engine was rebuilt 4 years ago, been running great until 2 months ago when it became hard to start than would not start. Tractor mechanic replaced distributor, was shot. I had already replaced plugs, points, condenser, coil, oil/filter, l etc but to much slop. So get it back and it starts running very hot, and rough. Back to mechanic. Distributor faulty so another new distributor. Get it back, runs, but not much power and again running hot. When I shut it off I got a radiator bath out the cap, emptied radiator and engine of all fluid. (after 1/2 hour of mowing. So back to mechanic with my thought it was blown head gasket. He finds a slight leak in radiator (which it always had) send it out for repair. I get tractor back, still not running right under load, running hot. Back to tractor repair shop. New head gasket. Get it back, starts right up, idles good, runs smooth to 1/3 throttle out of gear/no load. Under load, no power runs rough. Still running hot. I notice exhaust leak around rear of manifold so I get some gaskets and fix leak. Starts right up, sounds better but still no power under load. I shut it down and go to restart it, won't start. Not firing at all.
So, I check all fuel filters, clean as a whistle. replace oil in air filter/clean. Carb bowl is filling up. Check #3,4 plugs, dry as a bone and very white. pull off carb, open up, very clean inside. Blow out all jets and holes. needles clean, look like new. (carb is 2 years old). Install new gaskets, reinstall. Engine cranks forever but will not fire. When I stop cranking gas leaks out bottom of carb. Seem to be coming from the small hole in dimple in front of drain plug. Pull plugs, all dry as a bone. Idle mix screw is at 1/3 out, main 1-3/4 turns out. Just not getting fuel. Any idea's? HELP!
(quoted from post at 05:22:38 09/19/14) Hi, at my wits end with this tractor. A bit of history. Engine was rebuilt 4 years ago, been running great until 2 months ago when it became hard to start than would not start. Tractor mechanic replaced distributor, was shot. I had already replaced plugs, points, condenser, coil, oil/filter, l etc but to much slop. So get it back and it starts running very hot, and rough. Back to mechanic. Distributor faulty so another new distributor. Get it back, runs, but not much power and again running hot. When I shut it off I got a radiator bath out the cap, emptied radiator and engine of all fluid. (after 1/2 hour of mowing. So back to mechanic with my thought it was blown head gasket. He finds a slight leak in radiator (which it always had) send it out for repair. I get tractor back, still not running right under load, running hot. Back to tractor repair shop. New head gasket. Get it back, starts right up, idles good, runs smooth to 1/3 throttle out of gear/no load. Under load, no power runs rough. Still running hot. I notice exhaust leak around rear of manifold so I get some gaskets and fix leak. Starts right up, sounds better but still no power under load. I shut it down and go to restart it, won't start. Not firing at all.
Check for spark at the spark plugs! will it start on starting fluid?
Seems to be getting spark, just no fuel. Fuel is fresh, everything clean, just not getting to cylinders. Have not tried starting fluid yet.
6v or 12v? If it's 12v, tell us what resistors you have installed.
The first thing you need to do is find a new mechanic. He's taking you for a ride.
Or, you could learn to do this stuff yourself. Which is, I assume, why you are here.
That distributor problem could have been likely solved by a $7 set of bushings.
As to overheating, see tip # 24 at the link.
As R. Geiger suggested, check for spark & fuel; see tip # 13.
" Idle mix screw is at 1/3 out, main 1-3/4 turns out. "
Not correct. Both Ford and Marvel/Schebler (assuming you have a M/S carb ) say to set both the side-pointing idlemix and the down-pointing mainjet to 1-turn as a starting point. I set the down-pointing mainjet to 1-1/2 turns .
" Just not getting fuel."
Yes it is. In fact, it's getting too much fuel.
First, replace the plugs. If you flooded it, they're fouled & it will be it next to impossible to start. You don't need to toss them; heat the tips for a few seconds w/ a propane torch to burn off the invisible spark-robbing deposits from today's additive filled gasoline........or wash them in lacquer thinner.
" When I stop cranking gas leaks out bottom of carb."
The usual cause of gas dripping out of the carb throat is operator error.
While each N has its own starting sequence, none of them will start well by just yanking out the choke rod & holding it out for 5 or 10 seconds while the engine cranks. This is a gravity fuel system on a low compression engine; it is easily flooded by too much choke.
Try this:
Key on, gas on 2 full turns, clutch in, 3/4 throttle, press the starter button. Let it crank for at least 3 - 4 seconds before you pull the choke rod. Then, don't hold it out for more than 2 or 3 seconds.
If you find out it will not start w/o excessive choking, you have problems.
Post back w/ results or more questions.
75 Tips
The first thing that comes to my mind is timing. Of course you want to verify fuel and spark first cause that's easy to do and covers most problems, but after that you might wanna double check your timing and firing order.
Thanks for the advice. It was not getting fuel, plugs not fouled, bone dry. Just a very fine white dusting on them. I never have had to use choke to start engine, in fact it would flood it and if running kill it.
I took the carb back off, readjusted the float. Also found the pin missing from the back side that the choke spring attaches to. Fixed that.
Then I checked for spark, seems very weak. So I ran a wire directly from the battery to the coil and presto, running! Not perfect, but just ok. Looks like when the mechanic installed the new coil he must have lost the nut it came with, installed one a bit to big with different threads, would not tighten down/stripped. I worked on it some, made it better but still not really tight. Going to need another coil (will be 4th one!).
Then since they had the cowl off to change head gasket, I check the other end of the wire on the dash where several come together. They were all very loose. Tightened them down and tractor is running much better, though not perfect. I think I need to replace that junction, run new wires as they are looking kinda shabby. Also another coil, and then work on timing.
Engine runs best where adjusted right now, perhaps will change after I time it. Mechanic is refunding me about half what I spent, I will just have to find time to work on it myself if I want it done right.
Current idle is 400 rpm, is pretty smooth, no overheating now.
After I get engine better I need to fix leak in rear end, running out axle on left side. Getting worse by the week.
Also 12V system, don't know what resistor is installed.
Thanks!
(quoted from post at 14:07:31 09/18/14) 6v or 12v? If it's 12v, tell us what resistors you have installed.
Try this:
75 Tips
" I think I need to replace that junction, run new wires as they are looking kinda shabby. Also another coil, and then work on timing."
Make sure you get a 12 volt coil. (tip # 30 at the link) That way, all you need is the OEM resistor. ( as in the picture)
Replacing all the wires (along w/ the resistor & terminal block, is a good idea (see tips 27 & 42)
" and then work on timing."
Post back when you are ready to do that.
75 Tips
Thanks Bruce, will do. Have you heard of a tool used for timing that gives proper offset? Where available? i heard it makes the job much easier....
Thanks again,
Richard
(quoted from post at 05:17:16 09/19/14) " I think I need to replace that junction, run new wires as they are looking kinda shabby. Also another coil, and then work on timing."
75 Tips
Hi Bruce, got timing tool, ready to pull distributor and time. Understand most of the procedure except checking continuity. What do I set my meter on? What am I looking for a reading?
Thanks, Richard
(quoted from post at 12:12:29 09/27/14) Hi Bruce, got timing tool, ready to pull distributor and time. Understand most of the procedure except checking continuity. What do I set my meter on? What am I looking for a reading?
Thanks, Richard
Try looking at below URL. Very simple explanation.
I keep a cheapy Harbor Freight meter in the tool box of the tractor. In fact I have so many I keep them in all of my ATV's, cars and tool boxes. Its one of those freebie meters they give you when you buy something. Not the most accurate but gets the job done.
http://www.acmehowto.com/electrical/continuitytest.php
My Rube Goldberg continuity Tester :D
I made this tester about 35 years ago -- I think my first use of it was checking for shorts between the commutator bars on starter and generator armatures.
Well I pulled the new distributor out, first check points gap. Was only .004. Set to .015. Then hooked up the timing jig from Windy Farms, timing was way off. Had to take out retainer spring to rotate, moved 4 marks (advanced) till points started to open according to multimeter. If each mark is 4 degrees, than it was 16 degrees off. No wonder it ran rough and had no power!
Did all the recommended continuity tests, put it back together, reinstalled. Crossed my fingers and it it started right up to a fast idle. Turned the idle screw down 2 full turns to running at 420rpm. Readjusted idle mixture screw till it smoothed out.
Turned in main mixture screw from 4 turns out to 1-1/2 turns out. Running smooth at all rpms. Mowed thickest part of lawn at less than 1/2 throttle, did not bog down, went through it like butter (2nd gear). After 1/2 hour shut it down, did not boil over. Running much better than ever, even after it was rebuilt 4 years ago. I don't think the timing was ever set properly. Thanks to everyone here for all their help and advice, I now have a great running tractor!
Richard
:D
You're welcome. Glad to hear it's running.
" Was only .004."
And that's because of cheap points and/or no cam lube.
Get a set of Blue Streak points & check the gap & lube the cam annually. With new bushings, those points will easily last 5 years. (tips 66, 67 & 68)
75 Tips
