Will not idle down
Tractor had been running great until I had a problem with the Dist. cap that I posted about a few days ago. That is fixed now but something else popped up today while mowing. Move throttle lever all the way up but tractor will not idle down. If I give the choke a quick on and off and it does throttle down. What the heck is that all about??? (6V, front dist. 46, 2n)
Carb dirty maybe? Gunk causing it to stick just a little and the extra vacuum from the quick choke maybe unsticks it? Totally guessing here :)
Maybe the linkage got bumped while working on the distributor.
Springs all in place and hooked up on that linkage?
