1948 8N, ammeter has not worked for some time.
Bought a new one and it does not work either.
See attached wiring diagram. The Ammeter needle does
not move from zero when running.I get no voltage
across "A" to "B" with engine running. On the
Ammeter, I get 6 volts between terminal "A" and
ground and 6 volts between "B" and ground with the
engine running. What is the likely cause/fix?
