Probably a dumb question
Caryc
Ok, I just put a set of mower deck height chains on my 8N.
Since I usually leave the mower on the tractor all summer, is it ok to leave the mower hanging on the chains with the tractor parked?
I was just thinking about the extra weight on the parked tires. Rather than mess with unhooking the chains I could probably just put a couple blocks under the mower.
So is that a better idea than just leaving the mower hanging on the chains?
Look at it this way when they park a tractor that has wheel weights on it they do not remove the weights so pretty much the same thing. So yes it is ok to do that
(quoted from post at 11:33:00 09/10/14) Look at it this way when they park a tractor that has wheel weights on it they do not remove the weights so pretty much the same thing. So yes it is ok to do that
I do have wheel weights so that why I was wondering about the extra weight of the mower hanging on it also.
Thanks for the answers guys. :wink:
i use chains on my b hog and always park it up on blocks.not because of the weight though. want to keep some air flow around it and discourage criters from amking it a home. parked on the grass/weeds; not gravel or concrete. so you still may want to consider the blocks.
I"m glad you worry about things like this---it made me realize I"m not alone in my own worries about sometimes the non worry type issues. I"m a grease nut. use a machine 30 minutes and re-grease. Makes no sense.
(quoted from post at 16:06:43 09/11/14) I"m glad you worry about things like this---it made me realize I"m not alone in my own worries about sometimes the non worry type issues. I"m a grease nut. use a machine 30 minutes and re-grease. Makes no sense.
greasin's easier than repairin' :wink:
50 cents of grease will save a guy $500 in the long run. Just like if your going to do a job do it correctly or not at all
won't bother your tractor a bit.
My loader tractors have a very heavy counterweight
hanging from check chains....for years.
Your mower? only you can see it. Mounts areas ok and still strong? If it's rusty, there is a risk of a mount pulling loose from the weight.
I set mine down on a very large heavy machinery pallet
for the same reasons as the other guys, dampness, critters.
