I got the 8N that I was given started for the first time today, and it runs very well actually with the completed 12V conversion, rebuilt carb and tune-up.
I have a serious oil leak at the front of the engine, just under and in front off the govenor housing . I did not have a camera with me or I would post a pic of what I am talking about. I am not familiar with these engines, and is it very greasy. All that said, I cleaned it up as best I could and tried to find the source of the leak. It looks to me like it is coming from behind the cover on the front of the engine, behind the water pump. Timing cover maybe, that unbolts from the front of the engine, but the water pump, radiator, etc all look like they will need to be removed to get at it. It looks like it goes over the top of the crank, and mates on the bottom to the oil pan or a lip on the block, so I assume there are multiple seals that I will need to replace if I tear into this.
Can anyone tell me how big of a job (it looks like a day's work to me) this is and what gaskets I am going to need? I have some rear wheel seal leaks and it needs some brake work so I am trying to get a parts list together for my next order from YT.
