hydro oil leak
art amati
New User
Hi; I put my 9n back in service after several years of inactivity and hydro oil leaks out too fast. I assume that seals are dry. Is there some way to correct this problem? Is there a better hydro for old tractors.
Art A
Sounds like you may have water in your hydraulic oil. This will lift your oil level to the point it will come out the wheel seals.
(quoted from post at 13:11:21 09/02/14) You didn't mention where it is leaking from or what kind of fluid you put in it...
I looked up the proper fluid for the 9n,M2C134D now Ambra MultiG 134, now all is well.
Art
