8N ristpin advice
How do you get the ristpins in and out of pistons?
thank you all for all the help you have been to me
all these years. James
Should be a 'circlip' on either end (in the piston), remove same and you should be able to push them out with your thumb. HTH
Also, if they are varnished up a bit (from heat and oil and combustion products) they can be a bit stubborn.
If they are loose in the piston and move a bit and catch on the varnished area, some spray carb cleaner may help by dissolving the vanish.
Or,if they are simply snug in the aluminum pistons, warm the pistons up a bit with a heat gun or heat lamp.
