Dylan Black
New User
This message is a reply to an archived post by JBinNY on October 07, 2008 at 10:35:52.
The original subject was "1949 Ford 8N wont start no spark... advice needed".
Hey all, new to forum been doing alot of reading and still no headway on my 1949 8N front mount distributor. Alil about the tractor its a 1949 8n Front Mount Dist. and im having a problem. The problem is im not getting spark to my plugs. I have been following this post very closely and trying all things suggested but im still alil lost. I have replaced the voltage regulator, voltage reducer, coil, points, distributor cap, rotor cap, plugs, plug wires, wire to the coil, ign. condenser, and i have tried strectng the spring on the coil for better conductivity.I have replaced everything besides the Ign. Switch...
I bought this tractor from an older man who last had it running about 4 yrs ago and i had a small spark once and then noticed the voltage reducer was burned in half so i replaced it. Now the tractor has had the conversion done to it so it has the gm alternator on it. I also check all places possible with my multimeter and i have power going all the way down to the distributor and the power on the multimeter is reading 12v i dont know if thats a problem or not since its been converted from 6v to 12v, i also found out that there are 2 different coil a 6 and 12 but i was informed that ishould still get spark even if i have the wrong one.?. I have the points gaped at the prefferred setting with what folks were saying on here at .015. I also check the Ohms on the points and distributor and it all check out fine.
So with all that in mind any enlightenment and help would be awesome because at this time i feel lost and hopeless on this tractor. thanks any questions about something not covered please feel free to email [email protected]
