I have brain lock going, going over to go work on a 1952 8n sidemount 6volt original, what has happened is 2 young people who knew nothing about it saw the tractors battery, positive ground, having decided themselves that somebody put the battery in backwards they turned it around, [now negative ground] besides the charging system not working, which I don't know if it was working before or not, the tractor shut down after awhile, and would not start, I found that while I had 6v to the coil, and 6v to the dist. nothing was coming out the top of the coil and going into the distributor, the coil also looks very old, possibly the original one , I got a new coil today now what I cant find on here is if there is 6v going into the coil and the coil is good it will have stepped up voltage out the top right? it doesn't get that voltage elsewhere the coil steps the voltage up and sends it to the center of the distributor cap right? yesterday I didn't have any, also would the reverse polarity have fried the condenser or would that mater? like to get this going tonight I really don't have time this weekend to work on this tractor and they need it going
