My 8n (with hydraulic issues in a different thread) also has a battery/alternator issues. The details:
Front mount dist w/ 12 v conversion.
Bought new battery, tractor fired up and ran okay for a while, alternator appeared to spin fine.
Tractor restarted a couple times the same afternoon but I parked it and left the key in the on position accidentally.
The key also is stuck in the ignition, not sure if this is relevant.
The next day the battery was dead, only buzzing sound when I try to start. I got it jumped and let it run for 10 minutes or so to try to charge the battery.
I also recharged the battery overnight on trickle while hooked up to tractor. The next day I tried again and there was enough power to start it but carb issues prevented it from staying running. Battery fully dead again after turning starter for 30 seconds or so.
One observation is that after charging the battery all night the alternator was hot to the touch.... which I thought was weird.
Last night I unhooked the battery from the tractor an put it on the charger by itself.
Assuming the wiring is correct, my thoughts are that:
A. The alternator is bad (draining the battery/not charging)
B. The new battery is defective or ruined already (unlikely)
C. There's a short somewhere that's draining the battery while it's hooked up.
D. Nothing is wrong, a combination of leaving the key on, hard starting tractor have led me astray.
Thoughts?
Thoughts?
