will-max dairy
I'm sure that I'll get some flak for this, but I just bought a little Ford. I have no clue what the model is.
It cost me $1000, had brand new tires all of the way around. It was clean, it started quickly (and still starts quickly from a cold start, at least in summer) and its three point hitch works.
The seller only asked $1000; because, it had a "knock". If anything, it might have a slightly loose wrist pin. The knock is barely perceptible.
I previously owned a 640, so I have a little experience with similar tractors. I figured that even an engine rebuild wouldn't be too bad for this old machine.
So, where do I look to find out what model it is and find the serial number?
A couple of particulars:
-It has three forward speeds and one reverse on the console shifting lever.
-It has a unique high/low transmission range feature activated by a large lever on the left side of the transmission, just below the battery case (in front of the left foot peg).
Thanks in advance.
Chris
Thanks in advance.
Chris
