8n Ford tractor-----6 cylinder Funk conversion
I'd be careful with that much extra hp. Trans and rear are tough but were made for much less than a 6 or 8 cyl. conversion can pump out.
I would bet that if that is all you do, it will be fine. Now if you go & do things to stop or limit tire slip, such as weights, tire size, etc., then expect broken parts. Left stock tires & no weights, there is your safety fuse. But then, what use is the added power if you can't put it to the ground. Get a bigger tractor.
Weighted down for a tractor pull will result in a twisted axle and/or busted differential. Without weights, then in the words of Dirty Harry, "Do you feel lucky?"
