30 Weight vs 10W 30 Oil?
Gentlemen, I have a'51 8N that I have rebuilt and
used 30 Weight oil. I have initiated my first oil
change and was wondering if I could use 10W30 in
place of the original 30 weight that the manual
calls for. Will that be compatible?
I use 20W50 in most of my stuff. I buy the O'Reilly's brand oil since it is in fact Valvoline oil
Yes that will work fine! You may want to change weights depending on where you are located and the temperatures you will be operating at.
(quoted from post at 22:27:24 08/23/14) Gentlemen, I have a'51 8N that I have rebuilt and
Do your new engine a favor and use a quality multi-grade oil. Any quality engine oil in an xxW30 or xxW40 grade is fine.
TOH
agree with all.
a modern good multi-grade is what you want.
I prefer diesel engine rated oil in everything.
and since most of my tractor time is in the summer, long hours with the sun blazing down, I like the 15w40 blend on good motors.
(Like old, I will go to the 20w-50 with a tired motor)
(quoted from post at 09:32:43 08/24/14) agree with all.
[color=red:2e7ca1f174]I prefer diesel engine rated oil in everything.[/color:2e7ca1f174]
Be careful. The current love fest with diesel engine oils has been stoked by a lot of mis-informed FUD and ignores some very basic facts.
Diesel engine oils are formulated to address diesel fuel specific performance requirements. Gasoline engine oils are formulated to address a different set of performance requirements. The fuels and operating conditions differ significantly and the two sets of performance requirements do not interchange.
Engine oils that are suitable for use in both gasoline and diesel engines will carry a dual API service classification. Putting a diesel service only oil in a high dollar late model gasoline engine can wind up causing problems that could have been avoided - e.g. sludge/deposit buildup and emissions system related repairs.
TOH
Both your 30 and 10W30 will give you a viscosity of 30 at operating temperature, but the multigrade (10W30) will give you a significantly faster flow at startup.
Multigrade oils have a polymeric chemical in them that thickens with heat. that means that you can start off with a lighter oil for faster flow and as the engine heats up, the polymeric chemical (essential to a multigrade additive package) thickens and offsets the oils natural tendency to thin with heat.
I broke my 1953, 235 cu in engine in with 10W Non-Detergent
as per the book. Non detergent, because the oil filter is not located between the pump and the shaft bearings, but is located on the oil gallery where the oil pressure sender is located. The purpose for non detergent oil in that case was so as to not carry any break-in particulate to the bearings. After breakin' I went to detergent.
T
(quoted from post at 11:58:45 08/24/14)
T
Modern refining has gotten to the point where upper tier base oils can acheive 10W30 or better performance without the use of any VI modifiers. A number of oil producers have been blending some high quality synthetic multi-grades without VI modifiers for some time but you will work hard to find out exactly what products are made without them. Your friends at AMSOIL however have been hawking that performance in some of their products for almost a decade. Here is a link to their HD 10w30 that is formulated without any VI modifiers and is approved for API CH-4+/CH-4/SL service category use.
[u:f0d89b0a32]Amsoil HD 10W30[/u:f0d89b0a32]
Good stuff but not cheap at $40/gallon
TOH
PS> Just an additional note for those wondering why anyone cares. As I am sure you know the down side to VI modifiers is viscosity loss caused by shear down where, over time, the VI modifiers get destroyed by the shear forces inside the engine and a SAE 10W30 oil can be "sheared down" to SAE 10W20. That was a real problem in the "early years" and got multi-grades a (perhaps deserved) bad rap. But modern VI improvers are vastly more shear stable than the additives used 20 or even 10 years ago. Using high quality VI modifiers in combination with VHVI/UHVI synthetic base stocks today's blenders can produce engine oils with extremely wide viscosity spreads without sacrificing shear stability. To pick one example at random, Mobil 1 SAE 0W40 will easily stay in grade for 10k-15K in most automobile applications. That would have been impossible in 1970....
As usual, great analysis.
Other than unneeded expense, what are your thoughts on using diesel rated oil (10w40 Rotella, to be precise) in:
---- 8N's
---- 134 cid 740 Ford
---- 1929 Ford 4 cyl
---- push lawn mower
---- golf cart
The reason I ask.....the new M-F diesel requires diesel rated oil & I just hate to keep a different brand/weight of oil around here unless there is a specific requirement for that piece of equipment.
(quoted from post at 13:05:28 08/24/14) As usual, great analysis.
---- 8N's
---- golf cart
Rotella T Triple Protection SAE 15-40 is certified API CJ4/CH4/CI4/CI4+/SM/SL/SH/SJ plus a host of OEM (Cat, Mack, Volvo, Cummins, etc.) certs. That pretty much covers all diesel and gasoline automobile engines made to date ;-)
The golf cart, and lawnmower are "unknown quantities" so I'd consult the manuals for their OEM recommendations ;-)
TOH
I switched most of my machines to 15w40 a while back. After 17 us treats myself to a new rider mower and weed whacker, no oil mix. Both will take 10w30 thru 15w40, mower will take some 0w oil in cold climates, my tractors gas and oil are on 15w40, save 2 that are on store brand 10w30 sun, my diesel trucks are on valvoline prem blue 5w40 sun. No nor straight engine oils for me, :)
Old case vac even likes multiweight
(quoted from post at 07:10:06 08/24/14)
[color=red:8bbf9e63c8]I prefer diesel engine rated oil in everything.[/color:8bbf9e63c8]
TOH
TOH,
Thanks
I always look for your answers to oil questions.
I should have been more specific. My 'everything' was referring to all my old tractors and equipment. My only new tractor......IS a diesel :) (non-tier 4, Hobos post finally got me moving and I traded mine in for one of the last non-tier 4 new ones)
My truck calls for 5w-30 automotive gas rated engine oil...so that's what it gets.
I sell a lot of Chevron oils, have believed in the quality and what I see in the performance of my own stuff here at my farm.
Convenience is nice, but following a builders recommendations is good too, ---usually.
My 8-N is in very good shape, I only use it in summer when it"s hot weather. So--I use Chevron Supreme 20W/50, because I bought several cases of it awhile back for a very low price. I let it warm up a couple minutes, and off I go. Holds 38 LBS oil pressure when red hot, no problems at all using 20-50 there.
In 2 cars, we use Chevron Supreme 5w/30, and in car #3 it"s 10w/30. The book says it, so I do it, not any problems at all on these high mileage cars.
In 4 diesels I own, a John Deere 6330, a Dodge Cummins, and a Kubota ZD331 mower, and a John Deere Gator, I use Chevron Delo 400 CJ-4 15W/40. So--there are 4 oils I use. No big problem really. If I were out of 20-50, I would put in the 15-40 if need arose. The cars on 5-30 would be fine on 10-30 if need arose to do that, like being out of oil on change day. But mostly I stick with the book. Your old 8-N would do excellent on Delo or Rotella or Delvac or similar in straight 30 weight Most oils are premium these days, and no one is greatly benefitted using a 40 dollar gallon oil in an 8-N.
I use shell rotella 15w40 diesel oil in my old tractor and dodge diesel truck.
The old tractor holds better old pressure with this oil and I understand is still has the zinc additive that oils back in the day had to maintain bearing life.
(quoted from post at 16:34:24 08/25/14) I use shell rotella 15w40 diesel oil in my old tractor and dodge diesel truck.
Ah yes - the zinc/ZDDP FUD and misconceptions. Zinc has almost nothing to do with journal bearing protection. They operate in a hydrodynamic mode of lubrication that does not benefit significantly if at all from zinc or phosphorous compounds. It is primarily flat tappet valve lifters and camshaft lobes that are the concern with the lowered levels of zinc and phosphorous mandated by current standards. They operate primarily under boundary mode lubrication conditions that benefit greatly from EP type anti-wear compounds.
The zinc/phosphorous level in many 1950-1960 era oils was generally less than the MINIMUM (600 PPM) mandated by current API SM service class. If you doubt I have a virgin oil analysis of an old MM/MS/DG service class oil sample that shows phosphorous at 482 PPM and zinc at 572 PPM. That ratio is consistent with the use of ZDDP as the anti-wear additive containing those elements. Higher levels of ZDDP were introduced sometime around the 70's. While the increased levels did help limit valve train wear in top of the line specialty "high performance" flat tappet engines of that era the adoption was PRIMARILY intended as an anti-oxidant. ALL of the newer hotter running engines were experiencing increased oil oxidation that caused oil to thicken shortening oil service life and increasing engine deposits.
You REALLY don't need more than 600 PPM to protect a cold running 20 HP low RPM engine with 30# valve spring pressures. An N-series tractor (or even my "sporty" 1962 TR4 roadster) is more than happy at 600 PPM zinc/phosphorous which was typical of 1940's - 1960's formulations and it won't [u:f6ddf4fef8]measurably[/u:f6ddf4fef8] benefit from higher levels. If you are running a 400 HP high performance engine with flat tappet valve spring pressures in the 300-600# range you probably have a real reason for concern with ZDDP levels in modern oils and you may well see increased tappet wear using modern low ZDDP formulations. All of the performance characteristics and the history of ZDDP use I have described are abundantly well documented in a 40+ year long catalog of API and SAE laboratory testing and publications.
TOH
PS> AFAIK Ford never recommended a viscosity grade greater than SAE 30 for the N-series flathead. For sustained ambient temperatures under 90F they recommended SAE 20. For sustained ambient temperatures over 90F they recommended SAE 30. Source: the Ford owner's manual. Oil pressure aside , using SAE 40 in any grade formulation is a waste of very limited horsepower and expensive fuel.
