9N rewiring and 3-wire 10si alternator installation
Robert(AL)
New User
My wiring is bad and i need to install a new alternator. I bought a wiring harness from TSC and it doesn't have any instructions and it's for an 8N front coil. It's a 3-wire installation. Please help!
use gen arm wire for alt output stud.. tie the arm/bat wires together where the reg would be.
jump #2 on alt to charge stud.
use the gen field wire to connect to #1 on alt. at the dash.. run that thru a 168 or 194 bulb then to switched side of key.
