Would like to know what others have done to put forks on the buckets of their tractors with loaders like the Paulson loader on my ford jubilee.
I had planned to weld square tubing into the bucket then put square tubing inside the welded pieces in the bucket. would secure with pins. My main purpose is to lift logs, carry things that are too long to fit in the bucket. I would taper the ends of the square tubing that fit inside the welded square tubing welded to the bucket. Would use two pieces of square tubing for the forks. Pipe would work but I want whatever I use to be as thin as possible.
