Show Parts for Model:
Head problems
08-23-2014 14:44:43
I have a 1940 9N Ford tractor. For the past few years I have had oil in my antifreeze, so I decided to install a new cylinder head. When I put on the new head, I replaced some engine studs because some of the old studs seemed too short. When I tried to start it, I have water coming up thru the new studs around the head nuts, and it won't start. I have a terrible gasket leak. Any help would be appreciated.
Fuddy Duddy
08-24-2014 04:36:12
 Re: Head problems in reply to DFear, 08-23-2014 14:44:43
Oil in the radiator of one of mine meant a cracked block between two cylinders.
08-23-2014 19:38:35
Some of the studs can leak coolant if you do not use a sealer on them
08-23-2014 15:12:52
sounds like a botched head gasket job.. no offense.
Bruce (VA)
08-23-2014 15:00:29
" I have had oil in my antifreeze"
How did it get there?
While water in the oil is always a problem, oil in an N radiator is not usually a problem.
Anti-freeze has water pump lubricant in it. That's oil. Because it's a flathead, no oil lines are above the head gasket. But, you could have had a slight leak in the head gasket which will produce a sheen on the coolant thanks to combustion gases.
Did it have any performance problems?
What did the spark plugs look like?
Did you do a compression check?
Bottom line......
Unless you ran those tests, chances are you did NOT have a problem until you pulled the head.
Start over.
Get a new gasket.
Use sealer on the studs.
Use whatever sealer the head gasket calls for (some don't)
Torque the head nuts correctly (1/3, 1/3, & 1/3) in the prescribed pattern. Then, re-torque after a 30 minute run.
