Mike Rakow
Hello. I have a 9N (front mount/12V conversion). We are looking to set the tractor up to pull a small hayride wagon around the property Labor Day weekend. I am looking for some advice on how to properly set the drawbar so it keeps the trailer "level" for the ride.
Here is a photo similar to what I have right now. I have the stabilizer bars and the drawbar lock on the left side.
1.) First question is do I need a lock for the right side? When I look at the parts available, I do not see a left and a right application specified. If the "left" one I have swapped to the right, the groove for the stabilizer bar is on the bottom. I am assuming then that one bracket is all that is needed, is that correct?
Also, while browsing web images I saw these setups:
2.) What is the outermost bracket for...it appears to go from the drawbar up under the axle housing?
3.) what is the proper name for this outer bracket?
4.) Do I need them for my hayride set up??
Thanks. Mike
Thanks. Mike
