So i put water in my 8n and drove it into the garage to do brake work. Got all done and went to start it. However figured I would change oil first. A small amount of water came out, but oil was black, so I didn't worry much. New oil and filter and fired it up. Oh boy the thing smokes bad. More of a white smoke, so I said must be water. Checked radiator and slight smoke/must coming out. Note to self that can't be good. So i checked head and all bolts were not tight. Retorqued head and tried it again. Still smokes bad. So did I destroy the head gasket by running it without the head being torqued right? It was probably only about 6-8 pounds under.
Thanks.
Thanks.
