When the N lift is jerky coming up it means that one or more of the four pump cylinders is not pumping. It can be caused by broken springs in the pump chambers or a broken Scotch yoke in the pump that the pistons are attached to. Either one means the pump will need to be removed from the tractor to fix
75 Tips
Thanks Bruce should i worry about fixing it? Would it cause it to drop with just the drawbar in over night?
Drooping lift is USUALLY, leaking lift piston rings, could be other things like gaskets, valves or pinholed pressure tube
I think its dropping but I'm not 100 percent sure its dropping I have a 13 year old brother that likes to sit on it and move levers
