Hello...
I'm working on my brothers 1952 8N tractor...
The coil is bad(cracked on bottom and one side)No
fire going to points...fixing to get a new one...
It has been converted to 12 volts...
What is the correct voltage to coil feed wire...
I checked the resistor and is showing 12.9
voltage(battery voltage) I know that can't be
right...
What is the most safe voltage I need to be running
to the coil and does anyone know the what type of
resistor or the correct resistor to install...
If anyone knows the coil number and resistor napa
number please post it...Thanks Raner...
right...
