Jubilee Front Support Removal
Frank100
New User
Does anyone know what the procedure is for removing the front support? I need to get to the crank pulley. My manual is not very helpful on this procedure.
Do you actually have to remove the engine mount to replace the pulley?
I would have thought not but am more familiar with the 3 hole Fords.
Pull the tin off, remove the radiator hoses.
Knock the front end of one tie rod loose and one radius rod cap loose. Loosen the engine mount and swing it out of the way with the one tie rod, one radius rod and the radiator still connected.
EZ
Thanks for the feedback…I am not replacing the pulley. I am getting ready to put a front end loader on the tractor. The pump for the loader runs off an adaptor that mounts on the front of the pulley. There is not enough room for me to put the adaptor on with the front support in the way. Believe me, I tried.
I removed a front loader from my Jube and left
the loader pump drive adapter on, as you can see
in the picture. I have never had the adapter off
but it looks like if the bolt are short that one
could get it off without removing anything else.
good luck.
(quoted from post at 08:06:20 08/18/14) I removed a front loader from my Jube and left
good luck.
The adapter on yours looks the same as the one I have. I will look at it agian tonight to see if I can squeeze it on. The issue I saw is the bolts I need to use are a 1-1/2". Can I ask why you took your bucket off?
I removed the loader that came on the tractor
because it was the wrong loader and way way too
heavy for the tractor. I sold it to a friend who
needed it on a heavier tractor.
