scopecat1
8N has a Hupp motor co. high low trans. what would have to be done to do away with it , parts probably not available. :D
You will need to find the short shaft that originally went in place of the Hupp transmission . What it does is connects the tractors 4 spd transmission to the clutch/flywheel originally from the factory .The name of that short shaft has slipped my memory at the present .HTH ! God bless, Ken
