confused again
Anonymous-0
Hi.... I have had some great help from you guys regarding my recent 12v conversion. I followed the wiring diagram and tips as to why I was not getting spark. I have power to the coil but when I use the 12v probe tester, the gastank and negative ground shows hot... Is something shorting out?
(quoted from post at 09:19:04 08/11/14) Hi.... I have had some great help from you guys regarding my recent 12v conversion. I followed the wiring diagram and tips as to why I was not getting spark. I have power to the coil but when I use the 12v probe tester, the gastank and negative ground shows hot... Is something shorting out?
robably all in how you are using tester. Where connecting clip and where probing??
