TractorLinks.com
Order Ford 8N Parts Online
Re: 8n Front mount distribitor 6v
Patrick Wood
08-11-2014 04:46:53
The resistor block and terminal block are one in the same?
I know that the resistor has two connections and then there is a third bolt that has about 4 wires going to it.
Can you explain how works? Doe sthat supply a voltage to all those wires? Because teh wire that burnt had voltage as it was on teh same stud asthe Neg cable from the battery.
Bruce (VA)
08-11-2014 05:37:26
 Re: 8n Front mount distribitor 6v in reply to Patrick Wood, 08-11-2014 04:46:53
" The resistor block and terminal block are one in the same?"
While the terms are commonly used to mean the same part, your tractor has a resistor block......that's a terminal block to which a resistor is attached. A terminal block, used on mid-50's to 52 8N's, did not have a resistor.
" Doe sthat supply a voltage to all those wires?"
Google "wiring diagram JMOR" to get a visual of what it's supposed to look like wired.
The center post is the "common"; all but 2 wires attach there.
The top two posts are for the resistor. Attach the wire to the coil on the left & the wire to the ignition switch on the right. That puts the resistor between the switch & the coil.
As to your problem......
Make a visual inspection first, compared to the JMOR diagram. You will probably find something burnt at the short.
