Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: hat rim repairs
corchel1942
08-10-2014 21:06:17
Thanks for taking the time to reply. I dont know if mine are different or I'm reading this wrong, but the bolt holes seem to be sealed so you cant get to the channels from the opening.
I do like the idea of opening them up from the inside. It seems much thinner and easier to weld back up.
I will look at them closer this week, I still have a couple stubborn bolts to get driven out. Looks like I will be buying all new bolts too.
Thanks
Corey
Tall T
08-10-2014 21:24:51
 Re: hat rim repairs in reply to corchel1942, 08-10-2014 21:06:17
Can you post a couple of close-up photos?
I only know this type of hat rim, so I can't say.
Do the bolt heads look like carriage bolt heads?
Oh wait . . .
I think you're saying that there's a tight seal between the squared bolt passage and the hat channel innards. It seems to me that there are leakage points from within the bolt passage to the channel insides, probably filled with rust too.
Anyway, on the backside of your tire and rim, where the squared bolt boxed piece that's fixed in the channel, meeds the rim at one of the bolt passage corners, there's where I would drill a tiny hole for a spray wand. One could even seal that little hole with something before putting the bolt back in.
But if your hat channels look as good and solid as I thought mine looked and felt (dispite the pitting) don't even worry about putting anything in the channel . . . just dry it out and work at sealing your bolt holes so no more water gets in.
My bolts looked like nightmare Alice too but after a lot of work with wire wheel on bench grinder, chipping hammer and grinder finishing disk, they came up nice. I primered them too.
Cheers,
Terry
This post was edited by Tall T at 21:45:34 08/10/14 4 times.
Copyright © 1997-2015 Yesterday's Tractor Co.
