TractorLinks.com
Show Parts for Model:
Re: hat rim repairs
Fuddy Duddy
08-10-2014 20:52:05
I agree with you to a point. Most likely if he keeps it dry on the inside the rims will last him a long time. Removing and replacing the band would be a lots of work.
But your statement, "Don't fill them with foam whatever you do, or anything but solvents or oil or whatever." I have a little problem with. I take it that you are saying to coat the inside with oil? That would help stop the rust. But the oil would deteriorate the rubber tube as it would leak on to it.
Tall T
08-10-2014 21:03:13
 Re: hat rim repairs in reply to Fuddy Duddy, 08-10-2014 20:52:05
Very good point Fuddy Duddy!
So forget swamping the channels with oil because even if you thought you had all the pin holes to the tube sealed up, a new one could develop later.
I mentioned penetrating oils or whatever because he seemed to have his heart set on getting some rust inhibitor in there.
If I had elected to put a rust fluid into my channels I would have used Amsoil Metal Protector because it is incredible on rust and because the wetness eventually evaporates leaving a nice DRY rust inhibiting film. Ya, I know, I'm advertising again, but anyone with sense enough to try it will soon find out it is true.
The best way and with the least work would be to stick a spray can wand in to each channel section by using the bolt holes themselves for access even if that called for drilling a small wand-sized hole -- within that squared bolt passage.
Cheers,
Terry :)
This post was edited by Tall T at 21:41:04 08/10/14 3 times.
