TractorLinks.com
Show Parts for Model:
Re: Water Pump Replacement
Royse
08-10-2014 18:10:14
It's tight with the hood on, but doable.
Taking the hood off doesn't really gain you much except vision.
The radiator is still the same distance away unless you remove it too.
Then you might as well clean it up and paint it and....... LOL
Jim WI
08-11-2014 06:46:02
 Re: Water Pump Replacement in reply to Royse, 08-10-2014 18:10:14
I did sense that mission creep was very possible if I took the hood off. It would be so easy to decide to paint the hood as long as it was off. And then might as well do the fenders since I had the paint ready to go. And since it's a 2N, might as well do the cast parts since they are supposed to be the same color. And if I'm painting it, how about that new wiring harness and plug wire set. etc. etc. etc.
Right now, I need it back to mow with. I think I'll try it without removing the hood. Thanks to all for the input.
Bob
08-10-2014 18:55:50
Royse, you might want to tell him... With the hood removed and the coolant drained (or LEAKED) another 5 minutes will get the radiator safely out of the way to do a thorough removal of the water pump, and easy cleaning of the front block surface, and re-installation of the water pump.
Might as well "chase" the threads, as well.
And NO buggered up radiator fins.
