TractorLinks.com
Order Ford 8N Parts Online
8n stalling
Dan Schmitz
08-10-2014 17:49:50
My 8n stalls, usually after it is warmed up and under load. It seems like it is flooding out, and begins to sputter and then dies. It then starts very hard usually with the throttle wide open, and sometimes wont start unless it sits for an hour or more. I have put new plugs in it but that is all. Any ideas or help would be appreciated.
Bruce (VA)
08-10-2014 18:25:53
 Re: 8n stalling in reply to Dan Schmitz, 08-10-2014 17:49:50
It is important for you to tell us if your tractor has a 6 volt or 12 volt electrical system & if the distributor is on the front of the engine or on the side. The troubleshooting is different based upon the configuration of your engine.
It takes three things for an engine to run: spark at the right time, compression, & fuel/air in the right mixture. For the moment, forget about compression & concentrate on narrowing the problem down to spark or fuel.
There are three very important tools you always need to have in your N tool box: a 3 inch piece of wire w/ alligator clips on each end, a spark checker w/ an adjustable gap (* see below) and a 7/16 box end wrench. (see tip # 50 at the link below) And, you really do need a working ammeter on the tractor; it is a very important diagnostic tool. With these tools, you can quickly narrow down most N problems to spark or fuel.
Next time it stops, check quickly for fuel (** see below) then spark. When I say quickly, I mean get off the seat, grab the tools & do it right then. Do not wait a minute or two. First, check for fuel. Get a can & put it under the carb. Remove the bolt in the bottom of the carb; as long as the fuel is turned on, you should see gas flowing out of the carb. Let it run for at least 30 seconds. If itís a dribble, or runs for 5 seconds & stops, or none at all, you have solved half the problem: itís fuel related. If gas flows well out of the carb & only stops when you turn it off at the sediment bowl, chances are very good itís not a fuel problem. So, next, turn the key on, crank the engine & look at the ammeter. What is the needle doing? Does it show a constant discharge, no movement at all, or does it move back & forth slightly? Next, hook up your spark checker, turn the key on & crank the engine. If the spark jumps the 1/4Ē gap, you probably donít have a spark problem. If it wonít jump the ľĒ gap, you have a spark problem. If the ammeter needle shows a constant discharge, or doesnít move at all, that also tells you that you have a spark problem. Jump the ignition switch w/ your jumper wire & see what happens. If it runs, you found the problem. If it doesnít have spark after you jump the ignition switch, post back for more info on further troubleshooting. (and do not forget to turn the ignition switch off; see tip # 38)
If it does not have gas coming out of the carb at a steady stream w/ the bolt out for at least 30 seconds, you have a fuel problem. First, remove the gas cap. Your vent could be clogged & it vacuum locked. If that doesnít work, tap the carb bowl w/ a hammer handle in case the float is sticking closed. (donít whack it w/ the head of the hammer; you can crack the bowl). If you still donít see gas flowing, the N has three fuel screens; one in the brass elbow, one in the top of the sediment bowl & one on the stem of the sediment bowl in the gas tank. Check the screen in the elbow & the screen in the top of the sediment bowl. (donít worry about the one in the tank) Both probably need to be cleaned. If you have the fuel knob turned on all the way, & 1 gallon or less in the tank, it may be trying to feed off of the reserve inlet which is probably clogged. Only open it 2 full turns. Put at least 2 gallons in the tank. (and do not forget to turn the gas off; see tip # 9)
There are ways to check for spark & fuel that work & ways that don't. For example, having gas to the carb is nice, but having it past the float is what counts! Thatís why removing the 7/16Ē bolt in the bottom of the carb is the way to check for fuel. And, same thing w/ spark at the plugs. Some folks think that checking for spark means pulling a plug wire off & looking for one. Well, it's the distance the spark jumps at the plug that gives you the info you want. It takes about 17kv to jump a 3/16" gap & 22kv to jump ľĒ in the open air. Remember, itís 14psi outside of the engine & about 90psi at a 6:1 compression ratio in the cylinders & compressed air creates electrical resistance, so you really need the 17-22kv to fire the plugs when the engine is running. A store bought plug checker (in the picture) will work better than an old plug because it wonít shock the snot out of you like an old plug might!
Post back with results or more questions.
*If you donít own a spark checker w/ an adjustable gap, buy one. In the meantime, an old spark plug w/ the gap opened to at least ľĒ will work. Ground it to a rust & paint free spot on the engine turn the key on & look for a spark.
** On most gas engines, you would check for spark first. But, the N gas tank has a pin-hole size vent that easily clogs, causing vacuum lock. By the time you check for spark on a hot engine, the vacuum lock will dissipate w/ the engine off
Royse
08-10-2014 17:56:07
Are you getting black smoke out the tail pipe when that happens?
That would point to a rich/flooding condition also.
How long does it run before it acts up?
If you're not getting black smoke, I would check for spark at the
plugs as soon as it quits. Should be a good blue/white spark.
