Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Loader hydraulic too powerful
TheOldHokie
08-10-2014 15:58:56
Certainly sounds like you need to reduce the flow but you are still giving subjective descriptions. Give me something empirical. At ~1500 RPM engine speed how long does it take to lift the loader from the ground to full height? As a data point the Model 730 Ford loader had a full lift height of 10'-5". The unloaded lift time with a 19 GPM pump was 2.6 seconds and with the 14 GPM pump it took 3.6 seconds. That works out to 3-4 feet per second which is pretty snappy. What is the lift speed on your loader?
TOH
petertay
08-11-2014 07:33:47
 Re: Loader hydraulic too powerful in reply to TheOldHokie, 08-10-2014 15:58:56
My lift times for the full ten feet are similar to what you mentioned:
500 RPM - 9 seconds
1200 RPM - 3 sec
1500 RPM - 2.5 sec
Think that Northern Tools reducer mentioned by ScoutB would allow a decent lift rate while running at higher speeds such as plowing or moving dirt?
Thanks again.
TheOldHokie
08-11-2014 08:57:03
 Re: Loader hydraulic too powerful in reply to petertay, 08-11-2014 07:33:47
petertay said: (quoted from post at 10:33:47 08/11/14) My lift times for the full ten feet are similar to what you mentioned:
500 RPM - 9 seconds
1200 RPM - 3 sec
1500 RPM - 2.5 sec
Thanks again.
Nine seconds is way too slow for my taste and 2.5 seconds is PDQ. Sort of like porridge - too hot or too cold ;-)
If I used a flow restrictor it would be in the lift cylinder work circuit - not the pump supply line coming to the valve. The restrictor is going to create a substantial back pressure in the circuit and I wouldn't want the pump running full time into that sort of load for the very good reasons ScoutB gave you. I'd also use a one way restrictor so that you don't slow down the speed at which the lift drops. Here is a nice adjustable one that is a bit cheaper than the one from Northern Tool: Prince Flow Reducer
TOH
This post was edited by TheOldHokie at 09:00:44 08/11/14.
petertay
08-11-2014 09:09:21
 Re: Loader hydraulic too powerful in reply to TheOldHokie, 08-11-2014 08:57:03
I have ordered a flow reducer for the cylinder hose.
Thank you everybody (especially TOH).
