Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: hat rim repairs
Fuddy Duddy
08-10-2014 09:12:13
I'm a firm believer in sand blasting as the only way to truly deal with rust. That o'course would mean removing all the band and then replacing it with a new one. Just removing what is loose in there is not really going to do you much good. You won't hear it while the tractor is running. I have heard of people with rusted out bands to put concrete in there. But concrete is a corrosive. once the bolts are out you can most likely remove the loose scale thru the bolt holes and compressed air. You could then seal up all the holes with tape and put in some of the so called 'Rust Eaters' and roll it around to coat it. That is more of a feel good solution than anything. Not going to stop future rust. Others use electronics with some luck. Hopefully there is still enough good metal in there that it will last for years with just a good cleaning to what you can get to easily. Sand blast that part if you can at least.
