The tractor is an NAA with a Freeman loader from that era. The front PTO driven Hyd pump was shot so has been replaced. The problem is that the loader leaps up in the air when the lever is pulled, even if just barely touched. Apparently the new pump moves a lot more fluid than the old one.
The loader has very limited use as it wont move up slowly. It literally jumps up a foot in a split second. Replaced 1/2 inch the pressure hose with 3/8, but that did not help.
Any ideas? Some sort of reducer? --Thanks
