ford 2n milky oil
Ha royse dumped milky oil and replaced with 5quarts used
oil and one quart atf ran 30 min twice no milky oil . I will
drain and put knew oil in i think i got luckey with another
none running ford.actually drove tractor around with gas
tank in my hand.
if you have not drained it yet, dump/add in a quart of diesel and a pint of rubbing alcohol and run it around the yard a couple time. grab any hiding water and any emusified oil on the walls.
diesel will thin the oil, make it drain faster and carry out suspended solids... and it will disolve waxy emulsified oil
the atf you have in their is detergent rich.. thus it is suspending debris..
the alcohol is a polar solvent ( water is polar )and will disolve water left in the sump.
I wish icould remember all that iam a heavy equiment operator that would blow the minds of the mechanics at work most dont know what each additive does but would tell you to put it in the engine. Thalks for the explanation
