Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 8N Parts Online
8n no oil pressure
cdv
08-09-2014 17:53:20
just got done engine rebuilt new pistons,,,rings and sleeses,,crank cut 10 new bearings 10,,oil pump kit gears and bushing,,new oil pressure gauge fired it up no oil pressure,,oil is coming out line to gauge but not high pressure just slow blow air in all the oil line there ok ,,now it run good before but no oil pressure then that why I rebuilt the engine any ideals thanks cdv
Steve_N-TN
08-10-2014 18:14:17
 Re: 8n no oil pressure in reply to cdv, 08-09-2014 17:53:20
Just a thought but did they install both oil galley plugs? Depending on year, one behind the cam gear and later models one in the rear behind the flywheel. Hope its something other than this!!
cdv
08-11-2014 05:36:21
 Re: 8n no oil pressure in reply to Steve_N-TN, 08-10-2014 18:14:17
if the oil galley plug is out oil will leak out of back of block rite no leaks
Steve_N-TN
08-10-2014 18:17:23
Oops Chris--missed your post--sure hope that isn't the problem
cdv
08-10-2014 04:45:12
poured stp in front hole pack oil pump gears with bearing lude,,not loose I looked at the tube for cracks,, I have done many rebuilts
TheOldHokie
08-10-2014 03:29:18
 Re: 8n no oil pressure in reply to Dean, 08-09-2014 17:53:20
Or possibly a missing relief valve/spring.
TOH
soundguy
08-10-2014 09:36:25
 Re: 8n no oil pressure in reply to TheOldHokie, 08-10-2014 03:29:18
good idea.. missing or damaged spring. easy to overlook in a rebuild...
GB in MT.
08-09-2014 21:58:11
CDV;
Have you tried priming the oil pump???
Kind of hard to get to, but...pull this pressure relief plug and pump 80 to 90wt. gear oil into the hole. That will prime the pump.
If still no oil pressure....drain the oil out of the engine and check to make sure the pick-up tube is not loose, as LisaK suggested.
Here is the prime hole is.....(don't loose the spring and or the plunger!!!!
[URL=http://s162.photobucket.com/user/GB-1/media/oil_press_relief-1.jpg.html][/URL]
Gary
soundguy
08-09-2014 22:09:56
 Re: 8n no oil pressure in reply to GB in MT., 08-09-2014 21:58:11
If he's getting non pressurized oil out the op gauge line, sounds primed, but sounds like a galley plug out or something?
Lisa K
08-09-2014 22:51:21
 Re: 8n no oil pressure in reply to soundguy, 08-09-2014 22:09:56
It does sound primed but wouldn't a loose pick up tube cause low pressure? Who did the work on the engine? I know when we did my rebuild we packed the oil pump gears on assembly and primed it before start up. If the reason for rebuilding was no oil pressure and u have no oil pressure after s rebuild I can see the problem being the oil galley plug missing. 1 is behind the flywheel the other behind the drive gear on the cam.
soundguy
08-10-2014 09:20:59
 Re: 8n no oil pressure in reply to Lisa K, 08-09-2014 22:51:21
yep.. we always pack oil pumps too.
and ditto.. when i saw him say that it had no op and now has no op. i wonder if this is a new to him engine someone worked on, and left a plug out then passed the engine on?
LisaK
08-09-2014 20:54:47
Hows the pickup tube? Is it loose or did you check for cracks?
Copyright © 1997-2015 Yesterday's Tractor Co.
