Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Loader hydraulic too powerful
Mike Groom
08-08-2014 17:12:20
Sounds like you got the wrong pressure pump,maybe a 2000 psi instead of 1000?
soundguy
08-08-2014 17:58:46
 Re: Loader hydraulic too powerful in reply to Mike Groom, 08-08-2014 17:12:20
more of a wrong GPM pump.. vs pressure. 2500 psi is a common ag pressure.
He might have had an 8-12 gpm pump before and now has a 16-20 gpm pump.
the owner can reduce rpms and thus reduce flow, and try to feather the spool a bit more...
One thing i'd check is to make sur ethe valve is rated for the flow from the pump. if they are not a good match.. the pump will not like it as much.. however it sounds like the valve is NOT an issue. you can also get restrictor orifices and even 1-way restrictors that are full open in the other direction.. just be carefull with restrictors..
