Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: No Hydraulic Action
Ultradog MN
08-08-2014 04:38:32
Lot of those tractors ran for a lot of years and millions of hours without any filtration at all.
So I would say it's not crucial.
Yours wont hurt anything for sure but Zane is correct. And it is more exposed stuff to get hit and more places to leak or lose prime.
Ford didn't filter the hyd oil untill 1976. On the 26/3600 tractors they went to a gear pump which had the filter right on it.
Tall T
08-08-2014 08:39:03
 Re: No Hydraulic Action in reply to Ultradog MN, 08-08-2014 04:38:32
That's a beauty; a pump with a filter mount.
I like it!
I'm in no way going to imply that every tractor should have one
just because I happen to.
My tractor came this way is all.
I see what you mean about the hazards of the filter hitting something depending on the uses the tractor is put to. There would have to be some kind of protective guard around it in some cases I suppose.
I searched a WIX catalogue in the Hydraulic section and found every number surrounding mine but not mine exactly. so yesterday when ordering some 15W40 Amsoil for a friend, I ordered another Wix Hydraulic but they had to cross the number to a Donaldson.
I'm going to have to do some dub-checking.
As you know, when you simply follow what someone has done or installed before, you are sometimes blindly assuming they had it right. At first I crossed the Kralinator number to the WIX I just put on.
So maybe my filter housing is so old, that the number ceased to be listed in some catalogues. Wix 51259
Gatemouth Graham 8)
Vane pump article including pitfalls of suction side filtration!!
This post was edited by Tall T at 08:57:53 08/08/14.
08-08-2014 09:37:06
 Re: No Hydraulic Action in reply to Tall T, 08-08-2014 08:39:03
Filtration is great but pump starvation is not.
The chances of the filter hitting something are slim. The chances of ripping off the underside hydraulic lines on an NAA is orders of magnitude greater - dozens of documented cases of that.
Modern hydraulic systems use a strainer on the suction side and a filter on the return side. I'd strongly suggest using a Zinga AE-100 or equivalent wire mesh spin-on element in place of that paper element. You might have to replace the head to get it to fit but a Zinga AEF head is cheaper that a typical filter.
