TractorLinks.com
Order Ford 8N Parts Online
8n enigine on 9n tractor
Greg 1025
08-07-2014 15:31:01
I have a 9n tractor that has a engine that has been replaced with a 8n engine I believe to be a 1950 engine. I finally got the tractor running after I rebuilt the distributor, point, rotor, and coil and rebuilt the carburetor. I now have a problem I believe with the governor but when taking it off and checking everything it looked good, ball are round and the lower and upper races have no grooves, I put back together. I am now thinking from looking on this site that since the arms are different on the governor from the 8n and the governor on the 9n that they might have just used the governor that came with the newer 8n and hooked it up to the 9n linkage which is very different??? If this is the case how do I fix or what do I do? the tractor start and will idle fine but I have no or very little difference when I try to move the throttle up. I don"t believe that the linkage was binding but I cleaned the connections. Any help would be helpful.
Greg 1025
08-08-2014 03:54:48
 Re: 8n enigine on 9n tractor in reply to Greg 1025, 08-07-2014 15:31:01
Thank you, now to see if when re installed I can get the governor to work properly with the linkage .
John Smith8N
08-07-2014 18:22:50
 Re: 8n enigine on 9n tractor in reply to soundguy, 08-07-2014 15:31:01
Ok, then you have the correct governor. It may not be working or might have some issue keeping it from working correctly, but it is the right one for your tractor.
Greg 1025
08-07-2014 17:53:45
John I'm sorry I looked again and I have the one to the left in your pictures
John Smith8N
08-07-2014 16:44:34
This is the 9N and the 8N governor arms.
Which one do you have?
Greg1025
08-07-2014 17:49:24
 Re: 8n enigine on 9n tractor in reply to John Smith8N, 08-07-2014 16:44:34
The red one to the right which I think is the one for the 8n
