TractorLinks.com
Order Ford 9N Parts Online
Re: Ford 9n starting issue
old
08-07-2014 13:09:52
The coil maybe going bad so when you try to start it with the starter there is not enough amps to feed both the starter and the ignition system
Little Ed
08-09-2014 06:40:13
 Re: Ford 9n starting issue in reply to old, 08-07-2014 13:09:52
Since she is new to 9n"s, she needs to know about "Clean ,Bright, and Tight." All the electrical connections must be cleaned, polished bright with a wire brush, and good and tight. This is very important on 6 volt, Positive ground systems. I then spray mine with paint to seal out the weather. HTH
