Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Jubilee hydraulic accessory valve?
Beanmedic
08-04-2014 15:36:11
Did some of the Ford made hydraulic accessory valves bolt up to the top cover on the Jubilee or does it take something more creative? I have a valve like that on the 861 I am working on and will power a hydraulic top link cylinder with it. Kind of like the clean mount of a direct bolt on.
Beanmedic
08-08-2014 10:26:43
 Re: Jubilee hydraulic accessory valve? in reply to Beanmedic, 08-04-2014 15:36:11
Leonard, still looking for a way to contact you!
David
Tiger Joe
08-06-2014 05:26:32
any possibility one of these can be fitting to an N?
TheOldHokie
08-06-2014 05:42:49
 Re: Jubilee hydraulic accessory valve? in reply to Tiger Joe, 08-06-2014 05:26:32
No. For an N-series you need to be more creative. Here is one solution:
N-series Top Cover Modification
After making the modification mount and connect An open center control valve to the new tap. Alternatively you can skip the top cover modification and add an engine driven external pump which works even better.
TOH
Beanmedic
08-06-2014 05:08:15
Kirk, that's interesting. Didn't know they made that in a version with a handle. I thought about the diverter and can go that way if necessary. But would rather have a control valve. Can see that the valve would be handy with a scoop or box scrape.
leonard j. etta
08-05-2014 20:32:56
have an accessory valve no longer needed,more neat
and trim than those pictured,valve does not leak.
from an naa jubilee.if interested please respond by e-mail
Beanmedic
08-06-2014 08:27:08
 Re: Jubilee hydraulic accessory valve? in reply to leonard j. etta, 08-05-2014 20:32:56
Leonard, I just noticed you are new. Welcome to the forum!
Your profile does not provide any contact info and it is not enabled for email or private message. That's perfectly fine and many of these fine folks do the same. But I can't contact you except through this forum message.
I'll be glad to contact you if you provide me a means to do so. Or you can contact me. I previously posted my info above.
Thanks!
Beanmedic
08-05-2014 22:45:30
Leonard, I am interested! My email is turned on. In modern view you can see it. But here it is. My contact info:
Beanmedic@clanbean.com
404-276-8940 (cell - call or text) I'm Eastern time (Georgia)
This post was edited by Beanmedic at 22:50:32 08/05/14.
Beanmedic
08-05-2014 18:42:35
Thanks for the advise and pics. That makes all the difference in the world. The one I posted the picture of clearly is not for an NAA.
Guess I better keep my itchy fingers on the keyboard to pick one up when it shows itself! I already have the cylinder, so I'm part way there.
Kirk-NJ
08-06-2014 01:44:24
 Re: Jubilee hydraulic accessory valve? in reply to Beanmedic, 08-05-2014 18:42:35
I guess I should mention that the valve I have shown is more like a diverter valve. In other words with the valve engaged your 3pt arm won't work and your 3pt control quadrant would be used to power what ever you have the valve powered to like a snowplow,ect.
Kirk
Tall T
08-05-2014 21:49:01
This is your lucky day
Or should I say
Jubilee! :)
NNP
08-05-2014 06:41:49
see this question a lot.
Only NAA hydraulic stuff for NAA's (mostly)
Took some pictures to hopefully help
NAA only, accessory cover and valve
Underside of both
On my NAA
on my 600, looks to be the same basic valve with a different base
sorry, nothing I have pictured is for sale....
While tough to find for sale, they are out there and must have been popular. 3 of my NAA's and my 640 all had them when I bought them. And 2 of my NAA's cost less for the whole tractor than I see these valves going for on ebay.
This post was edited by NNP at 06:50:13 08/05/14.
Ultradog MN
08-05-2014 07:21:41
 Re: Jubilee hydraulic accessory valve? in reply to NNP, 08-05-2014 06:41:49
Real good, informative post NNP.
But what worries me is to hear you've been stealing NAAs again.
NNP
08-05-2014 07:47:33
 Re: Jubilee hydraulic accessory valve? in reply to Ultradog MN, 08-05-2014 07:21:41
LOL
I know you like working with basket cases too.
Most of the tractors I buy would have normal buyers
running away and having nightmares.......
Kirk-NJ
08-04-2014 17:56:15
This one is off my NAA.
Kirk
Beanmedic
08-04-2014 18:38:56
 Re: Jubilee hydraulic accessory valve? in reply to Kirk-NJ, 08-04-2014 17:56:15
Kirk, have you got a picture of the underside of that valve?
Kirk-NJ
08-05-2014 11:50:19
 Re: Jubilee hydraulic accessory valve? in reply to Beanmedic, 08-04-2014 18:38:56
Here a shot of the bottom
Kirk-NJ
08-05-2014 00:52:20
I'll get you a shot of it later today.
Kirk
Tall T
08-04-2014 19:43:27
You've probably already seen this long ago, so I don't know if this is helpful, but at 18:29 minutes into the 1953 Jubilee Promo video, the underside of the valve plate shows briefly.
Slide the progress bar button to precisely 18:28, start vid and you get a perfect shot of the underside before his hand obscures it.
https://www.youtube.com/watch?v=-8PS03-k50w
This post was edited by Tall T at 20:03:06 08/04/14 2 times.
Ultradog MN
08-04-2014 16:22:10
Yes they did.
Fit only on the NAAs.
They're hard to find though.
Usually more spendy than one for a Hundred too.
Beanmedic
08-04-2014 16:57:07
 Re: Jubilee hydraulic accessory valve? in reply to Ultradog MN, 08-04-2014 16:22:10
Hey UD. Was hoping you would weigh in. So this one...which is listed for a 600, 800, would not fit the NAA?
Ultradog MN
08-04-2014 17:43:42
 Re: Jubilee hydraulic accessory valve? in reply to Beanmedic, 08-04-2014 16:57:07
That's a real old one. I have only seen those on a Hundred Series but I know the valve itself was also used on the NAAs with a different plate.
Looking it over I'm not so sure.
Here are a couple of photos. One of a standard remote for a Hundred/Thousand.
Second photo is of the mount on the top cover on an NAA.
What makes me wonder is the three bolt holes - both in your second photo and my second photo.
The Hundreds all had 4 bolts.
I really am not at all familiar with the NAAs.
Maybe someone here can help.
