Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 8N Parts Online
Re: Ford 8N Hydraulic Raises on it's own and sticks up
WarnerT
08-04-2014 12:30:43
So if the valve(s) are stuck should I clean it like Bruce said or do I need to replace those valves as well?
I meant that he implied they are functionally the same. I understand they are physically different, is there a consensus on if the GL1 works fine in cold weather?
Bruce (VA)
08-04-2014 16:11:00
 Re: Ford 8N Hydraulic Raises on it's own and sticks up in reply to WarnerT, 08-04-2014 12:30:43
" do I need to replace those valves as well?"
Probably not.
" GL1 works fine in cold weather? "
It does in VA! But 30* is cold around here.
WarnerT
08-05-2014 05:31:24
 Re: Ford 8N Hydraulic Raises on it's own and sticks up in reply to Bruce (VA), 08-04-2014 16:11:00
Update: I got down in there again last night and tried with all I could to get the exhaust or inlet valve to move by hand. No luck. The only thing I can figure is that the inlet valve is stuck open and the exhaust valve is stuck closed. Explaining why the lift raises as soon as you let go of the clutch with the PTO on, even if the control is in the down position, does this seem correct?
Secondly, I hooked up the back blade for weight and looked in with the PTO running. There's about a 1/4" stream of fluid running down from what I think is the ram cylinder. This explains why the arms fall down on their own.
So my thinking is that I have to fix that leak and I have to unstick or replace the two valves, and clean out everything, at a minimum. I think I have to concede to dropping the whole pump and cleaning it thoroughly and pulling the cylinder out also to repair that.
I'm assuming I should find out EVERYTHING that's wrong before I start taking stuff apart? I haven't drained any fluid to this point, so how much oil do I need in there to operate the pump and still be able to find additional leaks? As of now I'm still unable to see what's going on very well due to the fluid.
Bruce (VA)
08-05-2014 05:40:48
 Re: Ford 8N Hydraulic Raises on it's own and sticks up in reply to WarnerT, 08-05-2014 05:31:24
" I'm assuming I should find out EVERYTHING that's wrong before I start taking stuff apart?"
Your diagnostics are very good. You've done about all that can be done at this point: you need a top cover rebuild & a pump cleaning.
Check out the link below for a step-by-step on the top cover rebuild.
Plenty of us around here have done both, so just ask for help if something isn't clear.
WarnerT
08-05-2014 07:00:35
 Re: Ford 8N Hydraulic Raises on it's own and sticks up in reply to Bruce (VA), 08-05-2014 05:40:48
Thank you, will you re-post the link?
I'm not sure I want to tackle this quite yet but I'll take a look at the steps. Anyone have any idea how much parts might run me for this mess? If I do it I'm going to do it right and spend the money to replace whatever I can to not have to do it again in the near future.
