Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: live with leaking lift or repair?
08-04-2014 11:20:30
45m or 45s
45m might just be NORMAL!
if it leaks down in under a minute.. tat's fast.
in any even.. if it leaks down too fast.. it isn't a big deal to repalce gaskets and piston and oring, cyl if needed and relief valve.. etc.
Tiger Joe
08-04-2014 13:27:42
 Re: live with leaking lift or repair? in reply to soundguy, 08-04-2014 11:20:30
Pulled side cover after work. Lift up you can clearly see a steady drip of fluid dropping down from above.
I didn't run the tractor long enough for the fluid to get hot, but even cold I had about a 1-2 drops per second
Also stuck my hand down in the fluid and it's really dirty/gunky.
I'm thinking I need to get myself an naa piston and clean out my hydraulic pump.
Iirc didn't I read on here before you can flush this out with kerosene once you drain the fluid?
