ok i dont know who i agravated but per my other post you know my usual mowing tractor has already had problems, for the last 2 days ive been running the ford jubilee and brush hog in the heavy stuff, it usually does great but each day, after running app 2 hours or even more at indicated pto speed or a litte above, [ very little] all of the sudden it will run very rough, drop cylinders maybe backfire, id suspect electrical, but the problem can be overcome by advancing the throttle almost up to 1350 indicated, after about 10 minutes it can be slowly brought back down to the original setting, which could be a carb problem,it seems to me if it was electrical, advancing the throttle would make it worse, not better, im pretty familier withthe 50 tips even though those actually are for the N tractor, so to fix this what would cause the engine to do that after that much time running, 2 hours is long after the usual coil or condenser issues isnt it? what in the cartb would cause problems at mid range after that kind of time?
fuel pee stream steady is available at the carb plug, when it runs rough
