Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: live with leaking lift or repair?
Bruce (VA)
08-04-2014 07:16:04
If you're looking for something to do, go for it. You will get plenty of help.
But....as others are saying....a 45 minute leakdown isn't a problem.
Tiger Joe
08-04-2014 08:05:08
 Re: live with leaking lift or repair? in reply to Bruce (VA), 08-04-2014 07:16:04
What is the "ideal" or best case hold time for an implement? I swear that I've read on here that someone left a brush hog up overnight?!?! Honestly, I would be perfectly fine with a few hours, but right now what bugs me is I can actually hear the lift dropping when Im in the garage.
honestly, my tractor fix would be a test run, i know 45 min is livable, but I always strive for perfection. My dads tractor drops after about 10 min with some serious weight on the lift, so fixing mine will be a dry run so we are "experts" by the time we tear into his.
Bruce (VA)
08-04-2014 09:55:03
 Re: live with leaking lift or repair? in reply to Tiger Joe, 08-04-2014 08:05:08
" What is the "ideal" or best case hold time for an implement?"
Days.
I have 4 8N's & a 740; a disc will stay up for 2 days on one of the N's. It will drop to the ground in 30 minutes on another.
Before you start, see tip # 16 to make sure it's a top cover issue. It could be a leaky pressure relief valve.
And, before you start, it would be a wise move to get a jig from Zane Sherman to adjust the internal linkage. And, make a couple of “guide studs” by cutting the heads off of two 7/16-14 x 3 5/8” bolts. Also, if your lift cylinder rebuild kit has the leather washer, get CNH part number 87051231 which is the neoprene washer for the lift piston instead of the leather one.
The lift cover weighs nearly 100 lbs with the upper lift arms attached, & is very hard to maneuver. An engine hoist is an excellent idea. Remove the seat and spring, disconnect the upper lift arms at the knuckles. Remove the 14 bolts that hold the cover to the housing. (note that there are three different lengths) DO NOT remove the four nuts under the seat! Remove the right side inspection cover so you can remove the control rod tip from the pump intake valve. Lift the back of the cover straight up and slide a piece of wood under the cover to keep the tip of the control rod out of the rocker shaft. Once you are sure the control rod is out of the rocker shaft, you can then remove the cover. Turn the cover upside down, remove the four bolts that hold the cylinder to the cover, & use a little compressed air on the cyclinder to remove the piston. Check the cylinder for excessive scratches, hone if necessary. Install a new piston with "0" ring and backing washer in the cylinder. Install the CNH neoprene washer w/ the concave side toward the “O” ring. At this point, check the cam follower pin & the control rod. If the cam follower pin is worn replace it. Then, if you have a jig, adjust the linkage to specs. The ‘shade tree’ adjustment was to bend the control arm to compensate for normal wear in the linkage, springs & cam follower pin. If the control rod is bent, remove it & straighten it. (very carefully; they break easily!) Replace the gaskets under the cylinder and bolt it back on the cover. Put the gasket on the tractor (no sealer) and put the gude studs in place. Unless you do this every day or have eyeballs in your finger tips, get some help to guide the tip of the control arm back into the rocker shaft. (this is the point you will wish you had a engine hoist to hold the top cover while the control rod dances around the intake valve arm on the pump!) Align the cover holes up with the housing holes. Remove the guide studs. Tighten cover bolts, connect lift arms install the seat. Re-install the inspection covers with new gaskets.
Tiger Joe
08-04-2014 10:58:21
 Re: live with leaking lift or repair? in reply to Bruce (VA), 08-04-2014 09:55:03
Bruce,
the plan is to open the side cover up and take a look one evening when I have some time.
If i dont see major drips, I might throw a new valve in just because it so simple
I dont have any kids so if I leave something in the air on the back of my tractor, nobody is going to be around it anyway
NNP
08-05-2014 06:00:15
 Re: live with leaking lift or repair? in reply to Tiger Joe, 08-04-2014 10:58:21
45 minutes? not driving you batty with 'corrections' while running?
I'd leave it alone. The smallest snafu during the repair, and it will be worse than that....
I've had new tractors that leaked down after a few hours.
Complaining to the manufacturer does no good at all.
"some minimal leakdown is normal"
Telling them that my 70 year old tractors don't leak doesn't work either.......
Up to you....but the gremlins that control machinery breakdowns will always wait for the time your foot, etc, is under it, before they do the full hydraulic failure dirty trick...
showcrop
08-05-2014 04:54:47
When I was a thirteen year old kid, if you had a tractor in my neighborhood, I would have been around it one way or another.
