flembo
I have had this tractor for over 10 yrs and just started noticing the lift drifting faster then it used to, about 5 min. from full up with a 6' rake on it, it also knocks a little with a heavy load I am not to concerned about the knock because I don't feel it is excessive as a matter of fact didn't hear it at all today then realized I didn't have my hearing aid in. I removed the right side inspection plate and saw a drip from the cylinder about every 5 sec. so not worried about that but saw activity around either the pump cylinder valve plate or the tube that carries the oil up to the lift cyl. can't be sure which, nothing above the relief valve. Any better way to tell which is leaking before droping the pump. Also when I removed the inspection cover it appeared to have never seize on it as a sealant with no gasket. Is there a product used to seal a cover like that, with the same looks and feel of neverseize I had it all over me and every thing I touched and stuff I didn't know I touched. What ever it is it didn,t leak.
