Nick167
will a 9n engine head work on a 52 8n? I was wondering if it will work because of the oil canister use to be down farther toward the radiator so my question is will it work?
You would need make a bracket for the oil filter and the 9N head won't have holes to bolt the coil on. You will also loose power as the 9N head has a larger combustion chamber and will lower the compression ratio from 6.5-1 to 6-1.
Mark
