Ok, took side cover off, drained a bunch fluid and found a large stream coming from rear of pump real close to inspection cover. It appears to be below a square headed plug and I presume this to be the safety valve. When I shut tractor down the fluid kept coming till load sat on ground.
Does any one have a picture showing valve still in pump? Maybe sitting on the bench.
At least I know what wrench I get to farmerize
All I have been able to find in FO4 and other site's how-to section shows exploded views and Utube shows nothing.
Thanks again, Norm
Thanks again, Norm
