Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 8N Parts Online
Re: hydraulics on 8n
07-26-2014 18:34:54
A sticking control valve caused by dirty oil can cause this condition. When the lift goes all the way to the top of it's travel there is a big dowel pin that the ram cylinder piston makes contact with and pushes the control rod back to put the lift in "neutral" position.
Another thing that can cause that condition is the return spring is broken or in some way not pushing the control vavle back to the exhaust position.
You can check this by removing the right side inspecion plate and with the touch control handle in mid range and the little mode lever pushed down to draft mode you can reach in and manually move the control rod and thus the valve/s and see if the spring is pushing the control rod back after it is pushed forward manally.
