TractorLinks.com
Order Ford 9N Parts Online
Re: 9N will not start
Eric in Sonoma, Ca
07-26-2014 16:18:39
I jumped both ways. I got spark when I jumped battery to battery.
I did not get spark when I jumped it straight to starter.
I am aware that it is dangerous to jump battery to battery. I always wear eye protection. Thank you for the warning.
Do you think it is my starter?
old
07-26-2014 20:36:55
 Re: 9N will not start in reply to Eric in Sonoma, Ca, 07-26-2014 16:18:39
Maybe the starter or the starter ground or a weak 6 volt battery. With out a true load test a battery can read 6 volts but not have the amps to spin a starter
Bruce (VA)
07-26-2014 18:13:14
I'm not sure that the advice you're getting here is very helpful.
I suggested that you charge the battery & check it w/ a hydrometer. You said " I assume the battery is good because the lights work and I measure 6 volts with the multimeter ".
That's not a reasonable assumption.
You could easily have a discharged battery.
