TractorLinks.com
Order Ford 8N Parts Online
hydraulics on 8n
bob pelton
07-26-2014 12:35:29
recently I posted my 8n hydraulics wouldn't hold a position, before getting into it I tested again and put 100# wheelweight on towbar and hitch would lift it easily but it overshoots and then slowly settles back to the lift position handle setting and stays there for hours. not sure why it does this but going to hookup drag bucket and if it will lift and settle back and hold that I think I can live with it, any comments on why it acts this way?
mbramble
07-29-2014 15:38:28
 Re: hydraulics on 8n in reply to bob pelton, 07-26-2014 12:35:29
Yes, PTO must be running. You need to look into live hydraulics kits from Zane or The Old Hokie or the roll-your-own version from Kevin LaRue.
They provide hydraulics without the PTO....
Shawn Renfro
07-29-2014 15:14:20
I recently purchased a 1952 8N that runs pretty good, but I have a question about the hydraulics. Does the PTO have to be engaged to raise the three-point hitch arms? On this tractor, the hitch won't raise without the PTO running, so I assume the PTO runs the hydraulic pump. This is kind of a pain when using a mower since the mower can't be raised or lowered without the PTO-powered blade running. May just be the nature of the 8N. Any input, anyone?
ZANE
07-26-2014 18:34:54
A sticking control valve caused by dirty oil can cause this condition. When the lift goes all the way to the top of it's travel there is a big dowel pin that the ram cylinder piston makes contact with and pushes the control rod back to put the lift in "neutral" position.
Another thing that can cause that condition is the return spring is broken or in some way not pushing the control vavle back to the exhaust position.
You can check this by removing the right side inspecion plate and with the touch control handle in mid range and the little mode lever pushed down to draft mode you can reach in and manually move the control rod and thus the valve/s and see if the spring is pushing the control rod back after it is pushed forward manally.
Zane
bob pelton
07-26-2014 17:31:05
yes draft is up, please explain again just how that works if plow hangs up for instance what does draft do?
soundguy
07-26-2014 18:17:16
 Re: hydraulics on 8n in reply to bob pelton, 07-26-2014 17:31:05
draft control is not there to preventt he plow from hanging on roots.
draft control is a sensitivity setting. you set it so the plow runs at a certain depth thru a certain material.. if the material gets tougher, the plow is raised to maintain the lower draft setting.. etc. it's not there to snatch it up over tree roots.. etc..
Bruce (VA)
07-26-2014 17:59:16
" please explain again just how that works"
Tip # 58 at the link.
If it won't hold in position control, try the quadrant adjustment.
If that doesn't work, time to pull the top cover & adjust the internal linkage & probably replace the cam follower pin.
soundguy
07-26-2014 14:01:08
lil draft lever set up to position control?
