9n purchased royse
I purchased 9n has been sitting 3 years should i lube pistons before starting what should i use .noticed welds on block when i got it home but read posts very common . He said it had no spark and he had a lot of coils two cracked distributor
"should i lube pistons before starting"
I would soak them in ATF for a few days.
Sounds like the previous owner had ignition troubles.
Has it been converted to 12V?
Ballast resistor on the back of the dash?
I'm not sure about the welds on the block, not
knowing where they are.
Hopefully the PO cracked the distributor putting it on.
You should have it up and running in no time.
Congrats on the new tractor!
(quoted from post at 07:14:40 07/26/14) Royce pretty well cover what you should do I 2nd the ATF
Left my tiller out for 2 weeks, it rained (stupid me).
Locked up tight when I pushed it into garage. ATF soak for a week, pipe wrench on crank stub shaft. Broke loose with no effort at all.
Mr. Old's cure all elixir...works everytime.
