TractorLinks.com
Order Ford 9N Parts Online
9n purchased royse
tom bleeker
07-26-2014 06:48:38
I purchased 9n has been sitting 3 years should i lube pistons before starting what should i use .noticed welds on block when i got it home but read posts very common . He said it had no spark and he had a lot of coils two cracked distributor
tom bleeker
07-26-2014 10:17:17
 Re: 9n purchased royse in reply to tom bleeker, 07-26-2014 06:48:38
Sorry 2n it still has geny with the high low screw one wire. its not locked up
old
07-26-2014 07:14:40
Royce pretty well cover what you should do I 2nd the ATF
JCinKY
07-26-2014 08:00:08
 Re: 9n purchased royse in reply to old, 07-26-2014 07:14:40
Left my tiller out for 2 weeks, it rained (stupid me).
Locked up tight when I pushed it into garage. ATF soak for a week, pipe wrench on crank stub shaft. Broke loose with no effort at all.
Mr. Old's cure all elixir...works everytime.
Royse
07-26-2014 07:03:27
"should i lube pistons before starting"
I would soak them in ATF for a few days.
Sounds like the previous owner had ignition troubles.
Has it been converted to 12V?
Ballast resistor on the back of the dash?
I'm not sure about the welds on the block, not
knowing where they are.
Hopefully the PO cracked the distributor putting it on.
You should have it up and running in no time.
Congrats on the new tractor!
